3550 per-packet load balancing
I know that already exist some threads concerning per-packet load balancing, but can someone confirm me if 3550 switches support per-packet load-balancing?
Thank you.
Best regards,
8 Replies 8
Ganesh Hariharan
Thank you.
Best regards,
Catalyst 3550 switch prompt commands  are not supported in this release Cisco IOS Release 12.1(19)EA1, either because they are not tested, or because of Catalyst 3550 hardware limitations.
Check out the below link Hope to help
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_19_ea1/configuration/guide/swuncli.html
If helpful do rate the post
Ganesh.H
Edison Ortiz
No, it does not.
Thank you to both.
Best regards,
does the 4900 switches support this feature? And any router supports this?
The feature navigator seems to be out dated.
Thank you.
Best regards,
I believe the 4900 does not as well.
Fancisco
Routers support the per-packet load balancing. 4900 is a switch - no support on that hardware.
Ok, thank you again.
By the way, there is another site beside feature navigator where we can check this kind of questions?
Best regards,
The documentation for the intended hardware (if it is a switch) - or the IOS documentation (if it is a router)
http://www.cisco.com/cisco/web/psa/default.html
