Can 2 different MLFR bundles from different PA cards be configured to a single access router and balance traffic across both bundles?
Feb 18th, 2010
I work for an ISP that connects educational customers to our network. We ocassionally run in to a situation where a customer needs multiple T1's, but unfortunately not all of them can come from the same PA card on the distribution end. We have set up mflr bundles coming from the 2 different PA cards, but the traffic is not balancing across those 2 bundles very well. Is there additional config needed for this kind of set up?  Thanks,
Giuseppe Larosa Thu, 02/18/2010 - 09:43
  • Hall of Fame,
    Founding Member
Hello Glen,
you should be able to setup MFR bundles also using ports from different PAs if you use a C7200 or other SW based router.
This is probably not possible with the flexwan on C7600/C6500
if you define two bundles you then have two L3 interfaces and CEF will balance over them
Hope to help
Giuseppe
ggreen63304 Thu, 02/18/2010 - 09:54
Thanks for your reply, we use Cisco 7609 for the dist router, and a 2811 for the access router. One Mflr bundle will max out, while the 2nd bundle is only at 50% capacity. Not a very good balance of traffic for this configuration.
