Voice Translation Rules
Answered Question
Feb 18th, 2010
i have an problem with voice translation rules
incoming and outgoing calls work but on the the phone and in the debug isdn q931 the calling party number is shown without the 0
here the debug:
001430: Feb 18 19:52:44.301: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x01
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x2183, '1751896976'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '5480080'
                Plan:ISDN, Type:Subscriber(local)
        High Layer Compat i = 0x9181
001431: Feb 18 19:52:44.349: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
001432: Feb 18 19:52:44.365: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8  callref = 0x81
        Progress Ind i = 0x8188 - In-band info or appropriate now available
001433: Feb 18 19:52:54.233: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x01
        Cause i = 0x8090 - Normal call clearing
001434: Feb 18 19:52:54.233: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x81
001435: Feb 18 19:52:54.321: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x01
here my rules and the dial peers:
voice translation-rule 3
rule 1 /\(^.+\)/ /00\1/ type national national
rule 2 /\(^.+\)/ /000\1/ type international international
rule 3 /\(^.+\)/ /0\1/ type any subscriber
voice translation-rule 4
rule 2 /^5480080/ //
rule 3 /^548008/ //
rule 15 // //
voice translation-rule 5
rule 1 /.*/ /5480080/ type any subscriber
voice translation-rule 6
rule 1 /^0/ /\1/
voice translation-rule 30
rule 1 /^.+/ /00/
voice translation-rule 2000
rule 1 /54800866/ /66/
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^7/ //
voice translation-profile PRI-AMT-OUT
translate calling 5
translate called 6
voice translation-profile PROFILE_ALL_BRI
translate calling 4
voice translation-profile Profl
voice translation-profile VM_Profile
translate called 2000
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
dial-peer voice 1 pots
description ** CCA Analog Fax **
translation-profile incoming PROFILE_ALL_BRI
destination-pattern 54800822
port 0/0/0
no sip-register
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number .%
direct-inward-dial
port 0/1/0
dial-peer voice 100 pots
direct-inward-dial
port 0/2/0
dial-peer voice 101 pots
direct-inward-dial
port 0/2/1
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 66
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 81
b2bua
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 80
b2bua
codec g711ulaw
no vad
dial-peer voice 53 pots
description ** outgoing dial peer **
translation-profile outgoing PRI-AMT-OUT
preference 1
destination-pattern 0T
progress_ind alert enable 8
port 0/1/0
forward-digits all
no sip-register
dial-peer voice 54 pots
preference 2
port 0/1/1
forward-digits all
no sip-register
dial-peer voice 51 pots
direct-inward-dial
port 0/1/1
dial-peer voice 55 pots
preference 3
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 2006 voip
description ** cue auto attendant2 number **
destination-pattern 82
b2bua
codec g711ulaw
no vad
dial-peer voice 2002 voip
description ** cue voicemail PSTN number **
translation-profile outgoing VM_Profile
destination-pattern 54800866$
b2bua
codec g711ulaw
no vad
i hope anybody can help me.
Correct Answer by Steven Smith about 7 years 1 month ago
Can you add an extra dial-peer?
dial-peer voice 5000 pots
incoming called-number 5480080
direct-inward-dial
port 0/1/0
The translation rules should add the 0.  We might need a debug dialpeer command.
debug voip dialpeer inout
Can you post that output?
Overall Rating: 5 (2 ratings)
Steven Smith Thu, 02/18/2010 - 12:14
  • Gold, 750 points or more
I assume you are trying to add a 0 with voice translation rule 3.  But, I don't see rule 3 applied anywhere.
On incoming calls, I see...
direct-inward-dial
port 0/1/0
Which looks for...
That does...
translate calling 4
I think what you need to do to fix this...
config t
translate calling 3
SKasper1975 Thu, 02/18/2010 - 12:34
sorry my english is bad. im a german guy.
i work remote on the uc so i can't see the display on the phone i called.
the debug shows the calling party number already without the 0 on the beginning.
There is a difference between debug and the number on  the display?
It may be that the display is consistent with the  number 0?
Steven Smith Thu, 02/18/2010 - 12:40
The debug shows no 0 on the call.  I assume the phone shows the same, no 0.  To fix this, try this.
config t
translate calling 3
Correct Answer
Steven Smith Thu, 02/18/2010 - 13:03
SKasper1975 Thu, 02/18/2010 - 13:08
here the debug:
001865: Feb 18 21:07:16.421: //-1/6D582FB38F8A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20008
001866: Feb 18 21:07:16.429: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=001751896976, Peer Info Type=DIALPEER_INFO_SPEECH
001867: Feb 18 21:07:16.429: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=001751896976
001868: Feb 18 21:07:16.429: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
001869: Feb 18 21:07:16.429: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=001751896976, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
001870: Feb 18 21:07:16.429: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=53
     2: Dial-peer Tag=54
     3: Dial-peer Tag=55
001871: Feb 18 21:07:16.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001872: Feb 18 21:07:16.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001873: Feb 18 21:07:16.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001874: Feb 18 21:07:16.433: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001875: Feb 18 21:07:16.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=53
     2: Dial-peer Tag=54
     3: Dial-peer Tag=55
001876: Feb 18 21:07:16.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001877: Feb 18 21:07:16.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001878: Feb 18 21:07:16.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001879: Feb 18 21:07:16.433: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001880: Feb 18 21:07:16.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=53
     2: Dial-peer Tag=54
     3: Dial-peer Tag=55
001881: Feb 18 21:07:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001882: Feb 18 21:07:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001883: Feb 18 21:07:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001884: Feb 18 21:07:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001885: Feb 18 21:07:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=53
     2: Dial-peer Tag=54
     3: Dial-peer Tag=55
001886: Feb 18 21:07:16.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=5480080, Peer Info Type=DIALPEER_INFO_SPEECH
001887: Feb 18 21:07:16.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=5480080
001888: Feb 18 21:07:16.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001889: Feb 18 21:07:16.465: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
001890: Feb 18 21:07:16.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=20014
001891: Feb 18 21:07:16.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001892: Feb 18 21:07:16.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001893: Feb 18 21:07:16.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001894: Feb 18 21:07:16.465: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001895: Feb 18 21:07:16.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=53
     2: Dial-peer Tag=54
     3: Dial-peer Tag=55
001896: Feb 18 21:07:16.469: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001897: Feb 18 21:07:16.469: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001898: Feb 18 21:07:16.469: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001899: Feb 18 21:07:16.469: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001900: Feb 18 21:07:16.469: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=53
     2: Dial-peer Tag=54
     3: Dial-peer Tag=55
001901: Feb 18 21:07:16.469: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=11, Peer Info Type=DIALPEER_INFO_SPEECH
001902: Feb 18 21:07:16.469: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=11
001903: Feb 18 21:07:16.469: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001904: Feb 18 21:07:16.469: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001905: Feb 18 21:07:16.469: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=20002
001906: Feb 18 21:07:19.717: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=11$, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
001907: Feb 18 21:07:19.721: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
001908: Feb 18 21:07:19.721: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
001909: Feb 18 21:07:19.721: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=14$, Called Number=, Voice-Interface=0x0,
001910: Feb 18 21:07:19.725: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
001911: Feb 18 21:07:19.725: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001912: Feb 18 21:07:19.725: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=13$, Called Number=, Voice-Interface=0x0,
001913: Feb 18 21:07:19.725: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
001914: Feb 18 21:07:19.725: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001915: Feb 18 21:07:19.725: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=12$, Called Number=, Voice-Interface=0x0,
001916: Feb 18 21:07:19.725: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
001917: Feb 18 21:07:19.725: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001918: Feb 18 21:07:19.757: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
001919: Feb 18 21:07:19.757: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
001920: Feb 18 21:07:19.757: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
002159: Feb 18 21:10:28.121: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 1751896976 N/A
002160: Feb 18 21:10:39.213: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1  disconnected from 1751896976 , call lasted 11 seconds
002161: Feb 18 21:10:39.237: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=81, Called Number=, Voice-Interface=0x0,
002162: Feb 18 21:10:39.237: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2001
002163: Feb 18 21:10:39.237: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
002164: Feb 18 21:10:39.253: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
002165: Feb 18 21:10:39.253: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
002166: Feb 18 21:10:39.253: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Correct Answer
Steven Smith Thu, 02/18/2010 - 13:38
direct-inward-dial
port 0/1/0
SKasper1975 Thu, 02/18/2010 - 13:45
i made it.
in the debug screens the number right.
003330: Feb 18 21:42:22.577: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003331: Feb 18 21:42:22.577: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
i think the problem is fixed
Steven Smith Thu, 02/18/2010 - 13:48
So, the problem was it was matching an outbound dial-peer on an inbound call.  So, there is a bit more you need to do.
You need to add other dialpeers for the other ports that you have.
You need to add other dialpeers for the other numbers that you have.
