WPA on 1242
Feb 18th, 2010
I am trying to upgrade the encryption on some 1242 access points.  I want to use WPA2.  When I go to set WPA it is requiring an authenication server address.  I don't want to use authenication.  Is there a way to implement WPA without authenication?
Milton Tizoc Mon, 03/01/2010 - 10:24
Hi Mark, i think you are using autonomous access point, if you try to configured WPA by web is a little complicated (for me), if you do it by CLI is faster here is a example to configure it:
dot11 ssid SSID-NAME
   authentication open
   authentication key-management wpa
   wpa-psk ascii PASSWORD
int d0
ssid SSID-NAME
int d1
ssid SSID-NAME
i hope this help.
Best Regards,
Milton Tizoc.
Milton Tizoc Mon, 03/01/2010 - 10:26
Sorry i forgot to put the encyption in the radios
int d0
ssid SSID-NAME
encryption vlan 15 mode ciphers aes-ccm
int d1
ssid SSID-NAME
Milton Tizoc.
Related Content
