VPN cient only working on one of two interfaces
Feb 18th, 2010
I have two interfaces "Outside" "Backup" and "Inside" (being ym inside netwoek
I can use the VPN client to access the inside network when I dial in using the "Outside" inteface - but cannot get it to work so that I can dial in using the "Backup interface"
It does not even get as far as Phase 1 and let me enter the login details as far as I can see, It is probably somthing obvious - can you have a look at config and let me know.
: Saved
ASA Version 7.2(2)
hostname thetford-firewall
domain-name thet.staceys.co.uk
enable password tXq1SIELZygvD6dc encrypted
names
name 192.4.0.254 Admin_host description Admin_Host
name 192.4.0.1 Thetserver description Thetford File Server
name 192.4.0.2 ThetTSserver description Thetford TS Server
name 192.1.0.0 Bury_LAN description Bury Local Area Network
name 192.2.0.0 Newmarket_LAN description Newmarket Local Area Network
name 192.4.0.0 Thetford_LAN description Thetford Local Area Network
name 192.168.1.0 Sudbury_LAN description Sudbury LAN
interface Ethernet0/0
nameif outside
security-level 0
ip address 216.36.180.46 255.255.255.248
ospf cost 10
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.0.0.100 255.255.255.0
ospf cost 10
interface Ethernet0/2
nameif backup
security-level 0
ip address 192.168.28.2 255.255.255.0
ospf cost 10
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
clock timezone GMT/BST 0
clock summer-time GMT/BDT recurring last Sun Mar 1:00 last Sun Oct 2:00
dns server-group DefaultDNS
object-group service WebAccess tcp
description Allowed protocols to Outside world
port-object eq ftp
port-object eq ftp-data
port-object eq www
port-object eq https
object-group network MAWHome
description MAWHome
network-object 192.168.0.0 255.255.255.0
access-list inside_access_in extended permit tcp Thetford_LAN 255.255.255.0 any object-group WebAccess
access-list inside_access_in extended permit tcp host Thetserver any eq domain
access-list inside_access_in extended permit udp host Thetserver any eq domain
access-list inside_access_in extended permit tcp host Thetserver any eq smtp
access-list inside_access_in extended permit tcp host Thetserver any eq pop3
access-list inside_access_in extended permit udp host Thetserver any eq ntp
access-list inside_access_in extended permit ip Thetford_LAN 255.255.255.0 Bury_LAN 255.255.255.0
access-list inside_access_in extended permit ip Thetford_LAN 255.255.255.0 Newmarket_LAN 255.255.255.0
access-list inside_access_in extended permit tcp host ThetTSserver any eq pop3
access-list inside_access_in extended permit tcp host ThetTSserver any eq smtp
access-list inside_access_in extended permit ip Thetford_LAN 255.255.255.0 Sudbury_LAN 255.255.255.0
access-list inside_access_in extended permit tcp Thetford_LAN 255.255.255.0 any eq 465
access-list inside_access_in extended permit tcp Thetford_LAN 255.255.255.0 any eq 995
access-list inside_access_in extended permit ip Thetford_LAN 255.255.255.0 192.168.0.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip Thetford_LAN 255.255.255.0 Bury_LAN 255.255.255.0
access-list inside_nat0_outbound extended permit ip Thetford_LAN 255.255.255.0 Newmarket_LAN 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 172.21.0.0 255.255.255.224
access-list inside_nat0_outbound extended permit ip Thetford_LAN 255.255.255.0 Sudbury_LAN 255.255.255.0
access-list inside_nat0_outbound extended permit ip Thetford_LAN 255.255.255.0 192.168.0.0 255.255.255.0
access-list outside_40_cryptomap extended permit ip Thetford_LAN 255.255.255.0 Bury_LAN 255.255.255.0
access-list outside_60_cryptomap extended permit ip Thetford_LAN 255.255.255.0 Newmarket_LAN 255.255.255.0
access-list outside_80_cryptomap extended permit ip Thetford_LAN 255.255.255.0 Sudbury_LAN 255.255.255.0
access-list outside_80_cryptomap_1 extended permit ip Thetford_LAN 255.255.255.0 Sudbury_LAN 255.255.255.0
access-list http-list2 extended permit tcp any host 62.189.96.209
access-list http-list2 extended permit tcp any host 213.120.81.201
access-list outside_100_cryptomap extended permit ip Thetford_LAN 255.255.255.0 192.168.0.0 255.255.255.0
access-list backup_20_cryptomap extended permit ip Thetford_LAN 255.255.255.0 Bury_LAN 255.255.255.0
access-list outside_nat0_outbound extended permit ip any 172.21.0.0 255.255.255.224
tcp-map mss-map
  exceed-mss allow
pager lines 24
logging enable
logging trap notifications
logging asdm informational
logging host inside Thetserver
mtu outside 1500
mtu inside 1500
mtu backup 1500
ip local pool VPNUsers 172.21.0.1-172.21.0.25 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (backup) 1 interface
nat (outside) 0 access-list outside_nat0_outbound
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 Thetford_LAN 255.255.255.0
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 216.36.180.41 1 track 1
route outside 81.179.236.186 255.255.255.255 216.36.180.41 1
route backup 0.0.0.0 0.0.0.0 192.168.28.1 2
route backup 88.96.71.198 255.255.255.255 192.168.28.1 1
router ospf 10
network Thetford_LAN 255.255.255.0 area 0
log-adj-changes
redistribute static subnets
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
group-policy DfltGrpPolicy attributes
banner none
wins-server none
dns-server none
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 4
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
password-storage disable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelall
split-tunnel-network-list none
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
msie-proxy server none
msie-proxy method no-modify
msie-proxy except-list none
msie-proxy local-bypass disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools none
client-firewall none
client-access-rule none
webvpn
  functions url-entry
  html-content-filter none
  homepage none
  keep-alive-ignore 4
  http-comp gzip
  filter none
  url-list none
  customization value DfltCustomization
  port-forward none
  port-forward-name value Application Access
  sso-server none
  deny-message value Login was successful, but because certain criteria have not been met or due to some specific group policy, you do not have permission to use any of the VPN features. Contact your IT administrator for more information
  svc none
  svc keep-installer installed
  svc keepalive none
  svc rekey time none
  svc rekey method none
  svc dpd-interval client none
  svc dpd-interval gateway none
  svc compression deflate
group-policy VPNUsers internal
group-policy VPNUsers attributes
wins-server value 192.0.0.1
dns-server value 192.0.0.1
group-policy VPNUsersbackup internal
group-policy VPNUsersbackup attributes
username abc123s password Ml encrypted
username 234567 password NC1e encrypted
username 67890 password 8BJ encrypted privilege 15
username 12334567 password Nqt/C0 encrypted privilege 15
http server enable
http Admin_host 255.255.255.255 inside
http Thetserver 255.255.255.255 inside
http ThetTSserver 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt connection tcpmss 1300
sla monitor 1
type echo protocol ipIcmpEcho 81.134.64.1 interface outside
num-packets 3
frequency 10
sla monitor schedule 1 life forever start-time now
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 60 set transform-set ESP-3DES-MD5
crypto dynamic-map backup_dyn_map 20 set pfs
crypto dynamic-map backup_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 40 match address outside_40_cryptomap
crypto map outside_map 40 set connection-type answer-only
crypto map outside_map 40 set peer 81.179.236.186
crypto map outside_map 40 set transform-set ESP-3DES-MD5
crypto map outside_map 40 set reverse-route
crypto map outside_map 60 match address outside_60_cryptomap
crypto map outside_map 60 set peer 216.36.175.6
crypto map outside_map 60 set transform-set ESP-3DES-MD5
crypto map outside_map 60 set reverse-route
crypto map outside_map 80 match address outside_80_cryptomap_1
crypto map outside_map 80 set pfs
crypto map outside_map 80 set peer 83.104.158.217
crypto map outside_map 80 set transform-set ESP-3DES-SHA
crypto map outside_map 80 set reverse-route
crypto map outside_map 100 match address outside_100_cryptomap
crypto map outside_map 100 set peer 80.177.219.168
crypto map outside_map 100 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto map backup_map 20 match address backup_20_cryptomap
crypto map backup_map 20 set connection-type answer-only
crypto map backup_map 20 set peer 88.96.71.198
crypto map backup_map 20 set transform-set ESP-3DES-MD5
crypto map backup_map 20 set reverse-route
crypto map backup_map 65535 ipsec-isakmp dynamic backup_dyn_map
crypto map backup_map interface backup
crypto isakmp enable outside
crypto isakmp enable backup
crypto isakmp policy 50
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 70
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal  20
track 1 rtr 1 reachability
tunnel-group 216.42.83.86 type ipsec-l2l
tunnel-group 216.42.83.86 ipsec-attributes
pre-shared-key *
tunnel-group 216.36.175.6 type ipsec-l2l
tunnel-group 216.36.175.6 ipsec-attributes
pre-shared-key *
tunnel-group VPNUsers type ipsec-ra
tunnel-group VPNUsers general-attributes
address-pool (inside) VPNUsers
address-pool VPNUsers
default-group-policy VPNUsers
tunnel-group VPNUsers ipsec-attributes
pre-shared-key *
tunnel-group 79.104.158.217 type ipsec-l2l
tunnel-group 79.104.158.217 ipsec-attributes
pre-shared-key *
tunnel-group 85.179.236.186 type ipsec-l2l
tunnel-group 85.179.236.186 ipsec-attributes
pre-shared-key *
tunnel-group 86.177.219.168 type ipsec-l2l
tunnel-group 86.177.219.168 ipsec-attributes
pre-shared-key *
tunnel-group 90.96.71.198 type ipsec-l2l
tunnel-group 90.96.71.198 ipsec-attributes
pre-shared-key *
tunnel-group VPNUsersbackup type ipsec-ra
tunnel-group VPNUsersbackup general-attributes
tunnel-group VPNUsersbackup ipsec-attributes
pre-shared-key *
telnet 192.0.0.16 255.255.255.255 inside
telnet timeout 5
ssh Admin_host 255.255.255.255 inside
ssh Thetserver 255.255.255.255 inside
ssh 192.0.0.16 255.255.255.255 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
class-map http-mapl
match access-list http-list2
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
policy-map http-mapl
class http-mapl
  set connection advanced-options mss-map
policy-map http-map1
service-policy global_policy global
service-policy http-mapl interface outside
ntp authenticate
ntp server 192.43.244.18
prompt hostname context
Cryptochecksum:15eac169386ef67f578a83d068c4cb2b
: end
