7200 Password Recovery - Fail
Answered Question
Feb 18th, 2010
I have a 7200, which I received on loan. I'm trying to reset the password and thereafter reset it back to factory defaults.
>show version - Configuration register is 0x2100
rommon 1> confreg 0x2100
rommon 2> reset
System Bootstrap, Version 12.1 (200000710:044039) [nlaw-121E_npeb 117], Development Software
Copyright (c) 1994-2000 by cisco systems, Inc.
C7200 platform with 262144 Kbytes of main memory
---instead of reloading, it reverts to rommon 1>
rommon > boot
Decompresses image and arrives right back to Hostname> . The end result is the same regardless of whether I cycle the unit or cli boot.
I've had to break the boot sequence a couple of times. Although it has arrived at rommon and couple of times as well after a boot instead of hostname>
-I'm confused; any input on this would be appreciated.
JC
Correct Answer by Jon Marshall about 7 years 1 month ago
JC
If you are trying to reset the password you are using the wrong configuration register, it should be 0x2142. See this document for a step by step guide -
7200 password recovery
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Thu, 02/18/2010 - 12:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
JC
Jon
