LMS 3.2 on virtual machine
Feb 18th, 2010
I have LMS 3.2 (100 devices license )installed on a windows 2003 server standard edition (32bits), and this is on a virtual machine (VMware ESX Server version 3.5.0) with 2GB RAM, 4GB of swap, and a Dual Xeon 2.33Ghz Processor.
After to install lms 3.2, windows 2003 show this message: "Generic host process for win32 services encountered a problem and needed to close".
Later, the ram memory grown until 3.8GB (physical memory+ swap memory), and when I try connect to lms portal the machine be inhibited.
Could you help me with this problem?
rplaza
Joe Clarke Thu, 02/18/2010 - 15:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you search for this error on Google, you will find it could have to do with missing security updates, or a possible virus/worm infection.  I have not seen cases where LMS triggers this error.  You might try some of the suggestions regarding updating the server's security patches, and running some anti-virus and anti-malware sweeps to see if they find infections.
