Can't ping across a Catalyst 2960
Answered Question
Feb 18th, 2010
Hello.
I have a Catalyst 2960. From default configuration, all I have done is assign a VLAN with an IP address of 192.10.200.1 and a subnet mask of 255.255.255.0. I am not setting a default gateway because there is no gateway - that field just stays at the default value.
This switch will not be connected to any other networks; it will only have a few computers on it that will be sending broadcast UDP packets to each other. I am able to send the broadcast UDP packets just fine, but I can't ping from any computer to any other computer. It would be nice to be able to do this for simple troubleshooting.
I will provide more information if that would help.
Please grace me with your abundant wisdom, O' Great Internets.
Correct Answer by Jon Marshall about 7 years 2 months ago
douglas.ctr.williams wrote:
Jon, thank you for the blazing fast response.
The connected computers have the following IP addresses and subnet masks:
192.10.200.11     255.255.255.0
192.10.200.12     255.255.255.0
They are configured as static with no default gateway.
Douglas
Okay then they are in the same subnet. By the way because the 2960 is a L2 switch it doesn't matter what you configure the vlan interface on the switch as in terms of vlan or IP address.
Couple of other things to check -
1) can you confirm that the computers in the same vlan ie. the ports they are connected into are in the same vlan. Should be as UDP broadcasts are working
2) can you make sure there is no personal firewall on the computers blocking the incoming ICMP requests
Jon
Overall Rating: 3.3 (3 ratings)
Jon Marshall Thu, 02/18/2010 - 14:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hello.
Douglas
Do the devices all have an IP address out of the same subnet and have the same subnet mask configured ?
Jon
douglas.ctr.williams Thu, 02/18/2010 - 14:17
Correct Answer
Jon Marshall Thu, 02/18/2010 - 14:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Douglas
Jon
nelson.garcia Thu, 02/18/2010 - 14:19
Douglas, A 2960 is just a layer 2 switch. As long as the devices you are trying to ping belong to the same subnet, they should be able to ping each other. If they're on different VLANs or subnets, you'll need a separate router.
glen.grant Thu, 02/18/2010 - 16:19
  • Purple, 4500 points or more
  I put my bet on  personal FW's on the clients blocking pings.
douglas.ctr.williams Tue, 02/23/2010 - 11:16
Thank you Jon and Glen.
It was indeed Windows Firewall that was blocking the ICMP requests.
Jon, your blazing fast responses are very much appreciated.
