Question, many wireless clients connecting in one loacation.
Feb 18th, 2010
I was wondering if someone could answer this for me. From what I have read, if you have more than 25-30 clients conncted to a single AP then bandwidth becomes an issue. We have situation in which up to 70 wireless clients will be gathering in a conference room that has one 1130AG LWAPP and I would like to add 2 more AP's to the room to accomodate the extra clients. Will the WLC and AP's automatically disperse the client connections between the 3 access points so that none of the access points become overloaded with too many connections? If not, does anyone have a suggestion on how I should approach this problem?
The equipment used is as follows:
4402 WLC
1130AG access points
HP 6735B laptops with Broadcom 802.11b/g WLAN adapters
Windows XP Professional
Thanks for the help.
Mark
Leo Laohoo Sat, 02/20/2010 - 17:17
If this is a small area then I recommend no more the three APs so the non-overlapping channels (1, 6 and 11) will not be having interference.
There's an option in the WLC on the Maximum number of Clients can associate.  By default it's set to 25.  How many clients can associate to an AP will also depend on the proximity of the APs to the clients and their respective signal strength.
mark shuford Sun, 02/21/2010 - 05:33
Thanks for the help. I did install only 3 AP's in the conference room but also set aggressive load balancing on that particular WLC as well. I will look into limiting the number of associations when I get back to work.
