Cisco VPN Client with Ncomputing thin clients
Feb 18th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
> I am running Cisco VPN Client Version 5.0.03.0530 on a WinXP box.
> I am also using Ncomputing L230s for thin clients.
> (http://ncomputing.com/Solutions/Lseries.aspx)
> It works like RDC and thin clients allowing multiple users to log in to the WinXP box.
> I am having a problem when two people start the VPN Client. The first
> one starts but the second one gets an error stating the client has
> already started or just does not start.
> Is there a way to get the client to run multiple times?
> Will the client run with Microsoft RDC or Terminal Services?
