WCS password reset
Feb 18th, 2010
  • Bronze, 100 points or more
Hi all,
I'm very new to WCS and the bloke that configured the bludger has left the company.  I'm trying to get into it but I don't have the correct username/password combination.
My query is:  How does one do a password reset on a WCS server?  Or failing that, is there a way I can ascertain the current unknown passowrd?
I have access to the actual server itself, but not the WCS application.   Searching around Cisco.com shows that apparently there is a utility that can be used to reset usernames and passwords however I can't seem to find it.  I'm not sure if it helps, but the WCS version is:  4.2.62.11
Any and all help will be appreciated and rated as such.
Brad
bmcginn Thu, 02/18/2010 - 20:38
All,
I found this in a wireless thread, ASK THE EXPERT:
Re: ASK THE EXPERT - WIRELESS CONTROL SYSTEM
I understand it's the login password that you want to reset on your WCS primary for GUI login.
Stop the WCS server :
C:\Program Files\WCS6.0.132.0\bin\StopWCS
Then run the root-user command:
C:\Program Files\WCS6.0.132.0\bin\passwd root-user PASSWORD
Start the WCS server:
C:\Program Files\WCS6.0.132.0\bin\StartWCS.
If this fails, please post your error messages from the CLI.
seems to work just fine!
Brad
sridhkri Fri, 02/19/2010 - 03:07
  • Cisco Employee,
You can follow the steps to reset your WCS password.
1. Go to WCS machine, where you installed the WCS application.
2. Go to command prompt, like
C:\ProgramFiles\WCSx.x.x\bin>>passwd.bat root-user America123
Outout:
Initializing...
Updating root password.
This may take a few minutes...
Successfully updated root user
Thanks and Regards
Sri
orlanfonzo Mon, 08/06/2012 - 08:29
Thanks Sridharan, your answer works for me! Stop the WCS Server was not necessary.
Related Content
