regarding ASA ASDM
Feb 18th, 2010
Hi All,
                My ASA software version is 8.2 (2) and ASDM version is 6.2(5) .Now I m getting the error when I try to launch asdm image from Vista OS PC. the error is : your firewall image has a version number null which is not supported by ASDM 6.2 (5). Plz help me to sort out this issue .
thanx and regards,
Taran
Brandon Svec Thu, 02/18/2010 - 21:46
  • Silver, 250 points or more
  • Community Spotlight Award,
    Small Business, February 2016
The versions are correct and should be compatible.  I just checked mine and they are the same.  I would bet that you have a Java issue.  I am using a Mac so mine is probably not the same, but I am running 1.6.0_17.
This used to work and then stopped, right?  What changed?  Did you just upgrade the ASA?  Did you upgrade Java?
Maybe someone here that is also at this latest version can verify what version of Java they have?
Brandon
