Replacing a Publisher hardware on CUCM 6.1.4
Feb 18th, 2010
I've been told, if I replace our current Pub with new hardware, I will have to rebuild both subscribers. Is this correct?
We have currently one Publisher and two subscribers.
I have built a new Publisher on new hardware with the same CUCM version, migrated licenses and MAC and restored the backup database. When I tested the new Pub live, I came across database replication issues, the Pub couldn't see the two Subs or viceversa.
Is there any workaround or a fix, to replace the Pub without having to rebuild the subscribers.
Let me know if you have any info,
Zeek
Overall Rating: 3.3 (3 ratings)
Rakesh Sabherwal Fri, 02/19/2010 - 00:25
Have you check in Publisher, having the node license installed. Is it showing node license 3 in license reports.
Rakesh
Rob Huffman Fri, 02/19/2010 - 06:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Zeek,
Sadly, the ability to replace the Publisher Node without
reinstalling the Subscriber Nodes was not introduced until
CUCM 7.1(2) or 7.1(3) Here is the related info for your
version;
Replacing the Publisher Node
Complete the following tasks to replace the Cisco Unified Communications Manager publisher server. If you are replacing a single server that is not part of a cluster, follow this procedure to replace your server.
Caution If you are replacing a publisher node in a cluster, you must also reinstall all the subscriber nodes and dedicated TFTP servers in the cluster, after replacing the publisher node.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_1/cluster/clstr611.html#wp87717
Cheers!
Rob
Tommer Catlin Fri, 02/19/2010 - 07:38
  • Green, 3000 points or more
You can try all the dbreplication tools from the CLI, but by the time those get done running and rebooting a node here and there, its just easier to rebuild the subscriber I have found.  Its only about 1-2 hours of time per subscriber to bring it back to normally operation in the cluster.
Zeek Ferraros Fri, 02/19/2010 - 08:29
I guess I will have to dedicate a night to replace the publisher and rebuild both subscribers.
Thanks for the help.
Zeek
