Problems with fail-over
Feb 19th, 2010
We are having some problems with out cisco 2800 router.
This is what we want:
We have 2 ISP's 1 fast (120mbit) and a backup (12mbit), the primary connection will be the fast isp on GigabitEthernet0/0.
The other connecting is on FastEthernet1/0 this connection is always online cause there are some route's over this uplink duo the permanent ip.
The routing is not working correctly. If the FastEthernet1/0 is going down the tracking system will remove the route and all traffic will go over GigabitEthernet0/0. When the FastEthernet1/0 is up again the tracking system will add the route again and the traffic that needs to go over the secondary isp is working agian. So till so far everything works
But when the GigabitEthernet 0/0 is going down/unreachable he removes the route and tells the router that all traffic needs to go over FastEthernet1/0 this works perfect for NEW connections, the current connections will fail cause he reminders some how that it needs to be over GigabitEthernet0/0
When i clear the cache all traffic will route over the second isp. Also when the primairy is back online again, All new traffic will work, current traffic is still over FastEthernet1/0
GigabitEthernet0/0 = Uplink fast ISP ip by DHCP
GigabitEthernet0/1 = Internal Traffic 10.1.0.x
FastEthernet1/0 = Uplink backup ISP ip by DHCP
Can please someone assist me and tell me whats wrong or whats needed to get this work fully.
Router config:
HCRouter#show run
Building configuration...
Current configuration : 4052 bytes
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret ***********
enable password ***********
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.1.0.1 10.1.0.99
ip dhcp pool Office
   import all
   network 10.1.0.0 255.255.255.0
   default-router 10.1.0.3
   dns-server 10.1.0.3
ip domain name Local.Domain
ip name-server 4.2.2.1
ip name-server 4.2.2.2
ip name-server 4.2.2.3
ip name-server 4.2.2.4
async-bootp gateway 10.1.0.3
async-bootp dns-server 10.1.0.3
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
l2tp tunnel receive-window 1024
crypto pki trustpoint local
enrollment selfsigned
revocation-check crl
rsakeypair my_key 1024 1024
username root privilege 15 password ***********
archive
log config
  hidekeys
ip ssh version 2
track timer interface 5
track 1 rtr 1 reachability
delay down 5 up 3
track 2 rtr 2 reachability
delay down 5 up 3
interface GigabitEthernet0/0
description Primary UPC
ip address dhcp
ip dns view-group name
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/1
ip address 10.1.0.3 255.255.255.0
ip nat inside
duplex auto
speed auto
no cdp enable
interface FastEthernet1/0
ip address dhcp
ip nat outside
duplex auto
speed auto
no cdp enable
interface Virtual-Template1
ip unnumbered GigabitEthernet0/1
peer default ip address pool vpn-pool
no keepalive
ppp encrypt mppe auto
ppp authentication pap chap ms-chap ms-chap-v2
ip local pool vpn-pool 10.1.0.70 10.1.0.99
no ip forward-protocol nd
ip route 89.255.0.23 255.255.255.255 GigabitEthernet0/0 254 track 1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 track 1
ip route 89.255.0.23 255.255.255.255 FastEthernet1/0 track 2
ip route 0.0.0.0 0.0.0.0 FastEthernet1/0 254 track 2
ip route 62.223.10.1 255.255.255.255 FastEthernet1/0
ip route 212.142.2.1 255.255.255.255 GigabitEthernet0/0
ip http server
ip http secure-server
ip dns server
ip nat translation timeout 3
ip nat translation icmp-timeout 3
ip nat inside source static tcp 10.1.0.14 22 interface FastEthernet1/0 7966
ip nat inside source route-map upc interface GigabitEthernet0/0 overload
ip nat inside source route-map xs4all interface FastEthernet1/0 overload
ip nat inside source static tcp 10.1.0.30 3389 62.195.4.214 3389 extendable
ip access-list extended MyNetwork
permit ip 10.1.0.0 0.0.0.255 any
ip sla 1
icmp-echo 212.142.2.1 source-interface GigabitEthernet0/0
timeout 1000
threshold 40
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 62.223.10.1 source-interface FastEthernet1/0
timeout 1000
threshold 40
frequency 3
ip sla schedule 2 life forever start-time now
no cdp run
route-map xs4all permit 10
match ip address MyNetwork
match interface FastEthernet1/0
route-map upc permit 10
match interface GigabitEthernet0/0
control-plane
banner login ^C
##################################################^C
line con 0
exec-timeout 0 0
password 7 02050D480809
logging synchronous
line aux 0
line vty 0 4
session-timeout 120
privilege level 15
logging synchronous
login local
transport input ssh
scheduler allocate 20000 1000
no process cpu extended
no process cpu autoprofile hog
webvpn install svc flash:/webvpn/svc.pkg
webvpn install csd flash:/webvpn/sdesktop.pkg
end
HCRouter#
kevinjansen Sat, 02/20/2010 - 05:26
I still dont have a solution, anyone haves some more information? Idea's ? everything is welcome.
KARUPPUCHAMY MA... Sat, 02/20/2010 - 06:23
  • Silver, 250 points or more
HI,
Can you paste the physical network connectivity of the current router to internet cloud.
Thanks & Regards
Karuppu
Lei Tian Sat, 02/20/2010 - 09:35
  • Cisco Employee,
Hi Kevin,
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
I think that's because the dynamic NAT entries for existing connections. One solution I can think right now is to use EEM ; when your lose primary connection, router will clear ip nat transaction; when primary connection comes back, router will clear ip nat transaction again. That requires IOS version 12.4(2)T or later. If your router running 12.4(2)T or later code, you can try to implement the following configuration.
event manager applet UP
event track 1 state up
action 1 cli command "enable"
action 1.1 cli command "no file prompt quiet"
action 2 cli command "clear ip nat translation *" pattern "#"
action 2.1 cli command "no file prompt quiet"
event manager applet DOWN
event track 1 state down
HTH,
Lei Tian
