ACE tcl script for radius request
Feb 19th, 2010
does anyone has an idea,
if I can send a complete radius authentication request with "user" and "pw" to check the functionallity of my radius with tcl scripting ?
if yes, some examples would be helpfull.
thx for every info
ciscocsoc Fri, 02/19/2010 - 04:55
  • Silver, 250 points or more
This will be "easy" if you can use PAP as the authentication mechanism.  The easiest way to do this (unless you want to write a full RADIUS client in Tcl) is to packet capture a simple PAP session - which is a request/accept over UDP and then modify the supplied LDAP script to send appropriate bytes and look for the response.  If you use anything more complicated than PAP then you're into a world of pain.  There are other posts on the forum where I have given additional information on modifying the LDAP script.
Hope that helps
Cathy
