Problems with EtherChannel on Cross-Stack Catalyst 3750 switches with WAN interconnection
Answered Question
Feb 19th, 2010
Hi to All,
need to configure EtherChannel on 2 wan site with the following enviroment:
On the 1st site there're 2 Cross-Stack Catalyst 3750
On the 2nd site there're 2 Cross-Stack Catalyst 3750
The connection between the 2 sites consist of 2 Gigabit links: the wan provider tell me MTU is end to end 9192 bytes
A) If I try to use the EtherChannel Without PAgP or LACP all is OK:
3750switchstackA(config)#interface range gigabitethernet 1/0/23 - 24
3750switchstackA(config-if)#channel-group 1 mode on
3750switchstackA(config-if)#switchport trunk encapsulation dot1q
3750switchstackA(config-if)#switchport mode trunk
B) If I try to use the EtherChannel With LACP the etherchannel NEVER go up !
3750switchstacka(config)#interface range gigabitethernet 1/0/23 - 24
3750switchst(config-if-range)#channel-group 1 mode active
3750switchst(config-if-range)#switchport trunk encapsulation dot1q
3750switchst(config-if-range)#switchport mode trunk
The question:
the problem is the 3750 interfaces MTU ?
the LACP need a bigger MTU on my 3750 switches (need to change it) ?
3750switchstackA#sh system mtu
System MTU size is 1500 bytes
System Jumbo MTU size is 1500 bytes
Roberto Taccon
Correct Answer by Lei Tian about 7 years 5 months ago
Hi Roberto,
LACP is an L2 control protocol, there is no encapsulation done by LACP. The LACP peers send out the special PDU to remote peer to verify if the peer is alive.
You can find out whether SP allow LACP frame by turn on debug lacp on your switch. Configure LACP mode active on both ends, and turn on debug LACP. If your provider allows the LACP control frame, you should be able to see "LACP packet received" and "Send LACP-PDU packet" from the debug output.
HTH,
Lei Tian
Overall Rating: 5 (1 ratings)
francisco_1 Fri, 02/19/2010 - 01:58
  • Gold, 750 points or more
MTU must be configured only on port channel interfaces and this MTU is propagated to the bundled ports. Make sure you are using LACP on both sides and the MTU match also on both sides.
ROBERTO TACCON Fri, 02/19/2010 - 02:27
the interface Port-channel 1 is configured with defaul MTU 1500.
How I can modify it ?
Is there any INTERFACE command to modify it ?
Need to modify the system MTU (which one MTU/routing/Jumbo) ?
3750switchstackA#sh int po1
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0013.7f59.6619 (bia 0013.7f59.6619)
  Description: 3750switchstackA
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi1/0/25 Gi2/0/24
  Last input 00:00:00, output 19:21:09, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     2505117 packets input, 3513326395 bytes, 0 no buffer
     Received 55871 broadcasts (55871 multicasts)
     0 watchdog, 55871 multicast, 0 pause input
     974779 packets output, 113948767 bytes, 0 underruns
     0 output errors, 0 collisions, 7 interface resets
itmil-calinf0r2-sw01DCMItoDCVR#
3750switchstackA(config)#system mtu ?
  <1500-1998>  MTU size in bytes
  jumbo        Set Jumbo MTU value for GigabitEthernet or TenGigabitEthernet interfaces
  routing      Set the Routing MTU for the system
francisco_1 Fri, 02/19/2010 - 03:15
using system mtu global config will affect all interfaces.
Try
conf t
int Port-channel 1
mtu ?
I think you can setup mtu on the portchannel itself.
francisco_1 Fri, 02/19/2010 - 03:33
You cannot set the mtu on interface level. you have to do it globally. OK. There is no mtu on the protchannel to decrease mtu. You cannot setup the mtu under the portchannel. What you need to do is  configure system mtu [setup your mtu) This will affect all ports under the portchannel. The port channe interface inherits the mtu from the physical interface when the interface becomes active.
Config t
system mtu
Lei Tian Fri, 02/19/2010 - 03:16
  • Cisco Employee,
Hi Roberto,
You need to consult your service provider make sure the SP can transparently pass LACP/pagp control frame. If SP block the control frame, you will not be able to use LACP/pagp.
HTH,
Lei Tian
ROBERTO TACCON Fri, 02/19/2010 - 03:41
The SP tell me: "the 2 wan links are transparent to the switches, the MTU is 9192 (MTU ethernet: with ethernet Header).
If the default MTU is 1500 bytes and the trunk 802.1Q requires an extra 4 bytes: the default interfaces MTU will be 1504 bytes... why the switch tell me 1500 bytes ?
How many extra bytes require LACP (are there any docs) ?
Are there any option to verify the MTU within the switch ?
How I can modify the MTU for only the Port-channel (channel of 2 Gigabit interfaces) ?
  Description: ** 3750switchstackA **
ON THE PO1 interface there isn't a MTU command (also on the GE interface)
3750switchstackA(config)#int po1
3750switchstackA(config-if)#?
Interface configuration commands:
  arp                     Set arp type (arpa, probe, snap) or timeout
  bandwidth               Set bandwidth informational parameter
  bgp-policy              Apply policy propagated by bgp community string
  carrier-delay           Specify delay for interface transitions
  cdp                     CDP interface subcommands
  dampening               Enable event dampening
  default                 Set a command to its defaults
  delay                   Specify interface throughput delay
  description             Interface specific description
  duplex                  Configure duplex operation.
  energywise              EnergyWise interface configurations
  eou                     EAPoUDP Interface Configuration Commands
  exit                    Exit from interface configuration mode
  flowcontrol             Configure flow operation.
  help                    Description of the interactive help system
  hold-queue              Set hold queue depth
  ip                      Interface Internet Protocol config commands
  ipv6                    IPv6 interface subcommands
  isis                    IS-IS commands
  iso-igrp                ISO-IGRP interface subcommands
  keepalive               Enable keepalive
  l2protocol-tunnel       Tunnel Layer2 protocols
  link                    Configure Link
  load-interval           Specify interval for load calculation for an interface
  logging                 Configure logging for interface
  macro                   Command macro
  max-reserved-bandwidth  Maximum Reservable Bandwidth on an Interface
  mvr                     MVR per port configuration
  neighbor                interface neighbor configuration mode commands
  network-policy          Network Policy
  nmsp                    NMSP interface configuration
  no                      Negate a command or set its defaults
  service-policy          Configure QoS Service Policy
  shutdown                Shutdown the selected interface
  snmp                    Modify SNMP interface parameters
  source                  Get config from another source
  spanning-tree           Spanning Tree Subsystem
  speed                   Configure speed operation.
  storm-control           storm configuration
  switchport              Set switching mode characteristics
  timeout                 Define timeout values for this interface
  transmit-interface      Assign a transmit interface to a receive-only interface
  tx-ring-limit           Configure PA level transmit ring limit
  vtp                     Enable VTP on this interface
Thanks to all,
Roberto Taccon
Correct Answer
Lei Tian Fri, 02/19/2010 - 04:42
  • Cisco Employee,
Hi Roberto,
HTH,
Lei Tian
