customizing product specific settings access
Feb 19th, 2010
I have made an implementation with a lot cisco 7925 and an CUCM 7.1.3
The customer wants that the settings access is restriced on every 7925. But they also want that the users are able to configure their own bluetooth Headsets.
Is there a posibility that they can acces the bluetooth settings in the phone even when the settings acces is restricted in the CM? or can i customize the settings which are restricted under the profile tab settings access under Product Specific Configuration Layout??
thanks a lot
Jaime Valencia Fri, 02/19/2010 - 06:41
You cannot customize what they can use, you only get the 3 options from CUCM in regards to access to settings.
You'll need to leave them open and once they configure the headset restrict them.
If this helps, please rate
