Linux OS not starting on server - Couldn’t find matching filesystem
Answered Question
Feb 19th, 2010
Hi all,
I have two call manager servers, that have been upgraded from version 4 (on windows) to version 5 (on Linux).
The upgrade took place two years ago. Last week, the following problem was encountered on the publisher during booting (after a power failure):
Couldn’t find matching filesystem: LABEL=/common
Give root password for maintenance
(or type control-D for normal startup)
At the Control-D, the system boots and gets back to the same error.
Does anyone have an idea how can I solve this problem?
Thank you.
Correct Answer by htluo about 7 years 1 month ago
This is a common issue if the system was not gracefully shutdown (such as a power failure).
You may use the Recovery CD to fix the file system.  Recovery CD can be downloaded from CCO:
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=7.1%283a%29&mdfid=282421166&sftType=Unified+Communications+Manager+Recovery+Software&optPlat=&nodecount=2&edesignator=null&modelName=Cisco+Unified+Communications+Manager+Version+7.1&treeMdfId=278875240&treeName=Voice+and+Unified+Communications&modifmdfid=null&imname=&hybrid=Y&imst=N&lr=Y
If you're running Linux version of CUCM, it's recommended to use the highest version of the Recovery CD.  (not necessarily match your CUCM version).
Hope this helps!
Michael
http://htluo.blogspot.com
Overall Rating: 5 (1 ratings)
Correct Answer
htluo Fri, 02/19/2010 - 05:14
  • Red, 2250 points or more
Hope this helps!
Michael
mazenelhourani Fri, 02/19/2010 - 05:41
Thank you for the link. I will download it now.
Some Linux forums told me to use the Linux CD (But it was a migration CD from version 4 on Windows to version 5 on Linux). I have people now looking for the migration CD. But I guess your link is better because it's a Linux Recovery.
I'll keep you posted if this works.
Thanks!
Best Regards,
Mazen!
