UCCX 7.0(1) + ESXi + Lab
Feb 19th, 2010
Hi All,
I am trying to setup ESXi in my lab for testing purposes. I have used the Cisco OS 2003.1.5a.iso as this passes the hardware detection. It all installs fine and I can also install UCCX 7.0 without an issue.
However when I go to browse to the http://servername/AppAdmin web site it fails with error 404, this is from the server itself and also a remote pc. I have reinstalled multiple times, installed the latest 2003.1.5a SR.
Has anyone seen this issue before?
Glen
Aaron Harrison Fri, 02/26/2010 - 01:04
  • Community Spotlight Award,
    Member's Choice, May 2015
Can't say that I have...
I take it you have verified that the Node Manager and Tomcat are running?
If so, then a good thing to try is going into this folder:
C:\Program Files\wfavvid\tomcat_appadmin\webapps
In there is an appadmin folder, you can delete this, and when you restart the Tomcat service it will be recreated from the appadmin.war file in the same folder. That often fixes problems with appadmin...
Aaron
Please rate helpful posts...
