Cisco 1760 router stays in rommon modus
Feb 19th, 2010
I am having problems with a cisco 1760 router. When I turn the router on I am getting stuck in rommon mode. When I enter the command: "boot flash:c1700-sv8y7-mz.123-11.T3.bin" , the router will boot the ios image. But when i turn the router off and on, it will return to rommon mode. I have tried the following commands in rommon mode:
rommon 1 > confreg 0x2102
rommon 2 > reset
or
rommon 1 > confreg 0x142
rommon 2 > reset
without results. I get the following errors:
System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2003 by cisco Systems, Inc.
Bad checksum on cookie structure, resorting to backup copy
Correcting primary cookie from backup
C1700 platform with 131072 Kbytes of main memory
loadprog: bad file magic number:      0x0
open: failed to find and/or load the bootloader: "flash:music-on-hold.au"
loadprog: error - on file open
boot: cannot load "c1700-sv8y7-mz.123-11.T3.bin"
boot: cannot load "flash:"
rommon 1 >
rommon 1 >
Pieter
Steven Smith Fri, 02/19/2010 - 08:05
I would recommend posting in the netpro forums about this.
http://www.cisco.com/go/netpro
This site is for the Cisco Small Business Pro routers.
For your problem though, you might try looking at your boot system command in your running config to make sure that it is accurate.
