Cisco IOS Release/Train codes
Answered Question
Feb 19th, 2010
I'm looking for the descrition of IOS Release/Train codes. I see alot of IOS releases (12.2SXE, 12.2SRE, etc.).
I know only some of them. For example: S - for Service Providers, T - Technologie train, E - Enterprise train.
But what about another: X, R, etc. ?
Can somebody help me to find a full description of ALL IOS Release/Train codes?
Thank you,
Piotr Covalciuc
Correct Answer by Ganesh Hariharan about 6 years 11 months ago
Thank you,
Piotr Covalciuc
Hi Piotr Covalciuc,
IOS routers would use the 12.4M (Mainline) or 12.4T (Technology). You will find the T train to contain the newest features but it may also contain the most bugs. We often recommend Mainline over T train if you are interested on stability in your network without the need of new features.
Other tracks would be platform specific, for instance;
12.2SX = Catalyst 6500
12.2SE = Catalyst 3xxx switches
12.2SR = Cisco 7600 Routers
12.2SB = Cisco 7200 and 7300 Routers.
and check out the below link hope that help !!
http://www.cisco.com/en/US/products/sw/iosswrel/ps1818/products_tech_note09186a0080101cda.shtml
If helpful do rate the post
Ganesh.H
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Fri, 02/19/2010 - 11:04
Thank you,
Piotr Covalciuc
Hi Piotr Covalciuc,
Ganesh.H
