clientless vpn bookmark
Feb 19th, 2010
Dear sir,
  In ASA 8.x or later, how to set up the bookmark or url list use the command line. I know how to build it use the ASDM, but can not find the right command in CLI.
esrios Sat, 02/20/2010 - 21:47
If you do not find the commands, I would suggest you apply the configurations from ASDM and then look into the running configurations.
show run webvpn
show run group-policy
Most likely these two outputs will give you the answer you are looking for.
xao Sat, 02/20/2010 - 22:36
Thanks a lot. But I want to know the command that define the bookmark.
