02-19-2010 08:10 AM - edited 03-04-2019 07:33 AM
Well, the topic is very self explanatory I believe.. I think that this issue is kind of related to WANs. I decided to focus my thesis on this problem for a ISP in my country, I would like to design a system (Point of Presence, Internet Exchange Point) here in the country able to separate internet traffic, send the international traffic out, and keep the national traffic inside the country, I assume that this is pretty complicated and requires a lot of resources and planning, but it would help me a lot if you could recommend some ways of getting on the road . I assume I may need to simulate a network with switches, routers, servers, etc. This design may be applicable to only one company running very little traffic, or for more than one, depending on the revenue that the project may generate, the basic idea to analize is if this project could lower latency and reduce overall cost for the company. But its also way too important analize how much a project like that may cost to implement. Thanks in advance for your insight!
Angel
02-19-2010 09:13 AM
A very loaded question. You might get more response if you post your ideas and allow us to critique them.
James
02-19-2010 12:36 PM
I don't think i understand the question.
Send international Internet traffic out and keep national traffic inside the country. Is this not what routers do?
02-22-2010 12:51 AM
Hello Angel,
your explanation may have been misleading.
ISPs use BGP communities for this job: some BGP communities can be used to mark routes that are national and differentiate them from international routes.
Multiple BGP communities can be associated to a single route and this is used for example to perform traffic engineering.
This is common practice.
If you refer to a different approach, somewhat based on analyzing traffic or performances on links, you may want to look at OER Optimized edge routing.
This is more oriented to enterprises then providers that need to use BGP.
see
http://www.cisco.com/en/US/docs/solutions/Enterprise/Security/IE_DG.html
http://www.cisco.com/en/US/docs/ios/oer/configuration/guide/12_4t/oer_12_4t_book.html
Hope to help
Giuseppe
