Slow Transfer Rate across VLAN
Feb 19th, 2010
Hello
On 4500 two VLANS are configured ; but transfer rate is very slow between two vlans
copy a file from one vlan to another vlan is slow its 20Kbps, host on both vlans are connected on 10/100 ports
Vlan 5
interface vlan 5
Vlan 6
interface vlan 6
ip address 192.168.2.1 255.255.255.0
4506==========2960
on 4506
interface giga 0/1
switchport mode trunk
on 2960
interface giga 0/1
interface fa 0/0
switchport more access
switchport access vlan 5
interface fa 0/1
switchport access vlan 6
If I change interface fa 0/1 to vlan 5, then transfer rate is OK
Ganesh Hariharan Fri, 02/19/2010 - 11:08
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hello
Vlan 5
interface vlan 5
Vlan 6
interface vlan 6
4506==========2960
on 4506
interface giga 0/1
on 2960
interface giga 0/1
interface fa 0/0
interface fa 0/1
Have you checked the duplex setting in switch ports and any errors in ports have checked and as you said both the vlan are configured in same switch.
Ganesh.H
nqtran1979 Fri, 02/19/2010 - 11:15
best to drop us the full config of the two switches. Easier for us to check
Won't be a duplex or speed issue as changing vlan resolves it, so maybe routing problem, spanning tree issue, etc
