limit bw from a subnet to 256K and allow all other traffic to take the remaining
Answered Question
Feb 19th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hello - object, limit bw from a subnet to 256K and allow all other traffic to take the remaining
Am I on the correct path? And, is this the most effective way to go about it?
access-list 1 permit 10.1.2.0 0.0.0.255 any
class-map police_me
match access-group 1
policy-map police_me_2_256k
class police_me
police 256 conform transmit exceed drop
int e0/0 (outbound interface to limit, traffic to limit comes in on a different interface, say e0/1)
service-policy output police_me_2_256k
Correct Answer by Jon Marshall about 7 years 4 months ago
atmpinniatm wrote:
Thank you - time to study up on the difference between policy and shaping
Put simply both policing and shaping have an upper limit beyond which they will not transmit the packet. Beyond this limit policing simply drops the packet whereas shaping buffers the additional packets until they can be sent.
This is why, as Paolo said, shaping gives a better performance from a user perspective.
Jon
Correct Answer by paolo bevilacqua about 7 years 4 months ago
Do not use policy. Use shaping.
Same effect but better performances for users.
Correct Answer by Edison Ortiz about 7 years 5 months ago
Yes, that configuration will provide a policer for the matched traffic.
Have you considered using CBWFQ for the matched traffic instead of policing the flows?
CBWFQ will only kick during congestion and it will allow the matched traffic to use more bandwidth than 256k during non-congestion.
class-map police_me
class police_me
bandwidth 256
class class-default
bandwidth (remaining bandwidth).
Overall Rating: 5 (3 ratings)
Correct Answer
Edison Ortiz Fri, 02/19/2010 - 11:17
  • Hall of Fame,
    Founding Member
class-map police_me
class police_me
bandwidth 256
class class-default
atmpinniatm Tue, 03/16/2010 - 05:05
Thank you. I want to put a hard limit of 256K on subnet X. i.e. it gets 256K and no more bandwidth – ever.
Through research I thought I would have to use WRED to ‘early detect’ bandwidth exceeding 256k and drop it??
I thought CBWFQ would all a ‘free for all’ except in times of congestion??
Assume traffic to be policed comes in via g0/1
So – will this do it?
Access list xyz permit subnet_X to_any
Class-map 123
Match access-list xyz
Policy-map 256000_limit
Class 123
bandwidth 256
  random-detect
   police 256000 conform-action transmit  exceed-action drop  violate-action drop
Interface g0/0
Service-policy output 256000_limit
Correct Answer
paolo bevilacqua Tue, 03/16/2010 - 06:13
  • Hall of Fame,
    Founding Member
atmpinniatm Tue, 03/16/2010 - 06:42
Correct Answer
Jon Marshall Tue, 03/16/2010 - 07:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
paolo bevilacqua Tue, 03/16/2010 - 08:42
  • Hall of Fame,
    Founding Member
The better performance is also from a circuit utilization perspective.
Because there are less TCP drops, hence less packet retransmissions and wasted BW.
