VRF and static NAT
Answered Question
Feb 19th, 2010
I want to do a translation on the ip destination. The host on the network 192.168.2.0/24 must ping the host  192.168.20.100 with the address 192.168.2.100.
The configuration is ok when there is no VRF. But when I setup VRF, there is no translation.Debug ip nat  and ip nat vrf  doesn’t  show anything, can you help me? Thanks.
This configuration is ok,  when a host on the network 192.168.2.0/24 pings ip address 192.168.2.100, icmp messages go to 192.168.20.100:
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.2.250 255.255.255.0
ip nat outside
ip virtual-reassembly
interface FastEthernet0/0.200
encapsulation dot1Q 200
ip address 192.168.20.250 255.255.255.0
ip nat inside
ip nat inside source static 192.168.20.100 192.168.2.100
This configuration doesn't work:
ip vrf forwarding
ip vrf  AZE
ip vrf forwarding AZE
ip nat outside
ip nat inside
ip nat inside source static 192.168.20.100 192.168.2.100 vrf ok
ip nat inside
ip nat inside source static 192.168.20.100 192.168.2.100 vrf AZE
Correct Answer by Lei Tian about 6 years 12 months ago
Hi Hache,
Looks like the NAT proxy-arp function is broken in vrf. The router stop responding the ARP request broadcast from client for 192.168.2.100. To make it work you can add a static arp on the router
arp vrf AZE 192.168.2.100  fa0/0_mac ARPA alias
HTH,
Lei Tian
Overall Rating: 5 (3 ratings)
Correct Answer
Lei Tian Sat, 02/20/2010 - 12:40
Hi Hache,
HTH,
Lei Tian
19652010Z Sun, 02/21/2010 - 00:33
Hi Lie,
I looked bad on cisco.com, I did not find this explanation, thank you for your response it's ok.
Hachesse
Related Content
