ACE Active Standby Syslog server
Feb 19th, 2010
Hello
How would you configure a ACE to manage de HighAvailability of 2 syslog servers.
Witch policy-map type should I use. When im using "load balancing" the logs are sent to both server.
------------ACE--------
Syslog1-----Syslog2
Ganesh Hariharan Fri, 02/19/2010 - 12:54
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hello
Syslog1-----Syslog2
You need to configure backup server in farm,check out the below link hope that clear your query !!
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A1/configuration/slb/guide/rsfarms.html#wp1000428
If helpful do rate the post
Ganesh.H
