Proper link-speed/duplex settings for 3750 to 3400?
Feb 19th, 2010
I have a 3750 connected to our providors 3400.  The connection had some issues this week, where I stopped receiving input packets, although the link remained in up/up state.  Bouncing the interface did not bring it back up.  However, changing the negotiation to auto/auto did.  We then changed it back to 100/Full, since it has been operating that way for months.
What should the proper setting be for a 3750 connected to a 3400?  Would auto work better than 100/Full?
T.J.
Ganesh Hariharan Fri, 02/19/2010 - 11:50
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
T.J.
Hi T.J,
It will work in auto negotiation as autonegotiation link partner abilities are negotiated and use a priority resolution algorithm to establish the best mode of operation but genral recommendation and best to harcode at both the end with 1000 Mbps/Full Duplex setting.
Check out the below link on auto negotiationsettings between interfaces.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af0.shtml#auto_neg_valid
Hope to help !!
Ganesh.H
tjalbrecht Fri, 02/19/2010 - 11:57
Ganesh,
I appreciate the quick response.  One issue is, my 3750 is only capable of 100/Full.  I am not sure, but I believe the providors switch may be capable of 1000/Full.  I will read over the link you sent.
Thank you,
T.J.
Amit Singh Fri, 02/19/2010 - 12:27
  • Cisco Employee,
Thomas,
Its better and suggested to put the devices with different transmition parameters to "auto-negotiation". This will make sure that both the devices best negotiate on a common ground as per their capabilities/characterstics.
http://en.wikipedia.org/wiki/Autonegotiation
Cheers,
-amit singh
Leo Laohoo Fri, 02/19/2010 - 16:17
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Thank you,
T.J.
Depends.  If you want to enjoy Gig link to your provider, the 3750 has a minimum of 2 SFP ports.
