Jaime Valencia Fri, 02/19/2010 - 12:21
  • Cisco Employee,
  • Hall of Fame,
    2011
With Cisco Unified CM 7.x, a cluster may contain as many as 20 servers, of which a maximum of eight may run the Cisco CallManager Service that provides call processing. The other servers may be configured as a dedicated database publisher, dedicated Trivial File Transfer Protocol (TFTP) server, or music on hold (MoH) servers. Media streaming applications (conference bridge or media termination point) may also be enabled on a separate server that registers with the cluster.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/callpros.html
If not your version, review the same chapter from the SRND for your CUCM version.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
David Hailey Fri, 02/19/2010 - 21:49
  • Purple, 4500 points or more
Yes, but it depends on CUCM version.  Hard and fast rules.  1 Publisher.  8 Subscribers.  From there, you can have
additional "cluster" servers that serve specific purposes without providing specific DB or call-processing functions such as
TFTP, MoH, etc.
Java's link to the SRND should be sufficient to give you the numbers you need for your version.  Any further questions, just ask.
