AnyConnect VPN software
Feb 19th, 2010
Hello all,
I was wondering if the AnyConnect software use the same .pcf file as the standard VPN client software?  I have no expereince with the AnyConnect software.
Thanks in advance.
All replies rated.
jimsiff Sun, 02/21/2010 - 02:03
AnyConnect uses XML profiles.  I don't believe they are compatible with PCF files used by the older Cisco VPN Client.
