Etherchannel Compatibility
Answered Question
Feb 19th, 2010
Do you happen to know if there would be any issues channeling between a port on a WS-X6724-SFP card and a port on a WS-X6748-GE-TX card?    I think this would be okay since they both can run at gig, but have seen some strange issues with etherchannel in the past so just trying to confirm.  Thanks.
Correct Answer by Reza Sharifi about 7 years 4 months ago
As long as speed and duplex is the same on both sides you should be fine.
Reza
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Fri, 02/19/2010 - 12:25
  • Cisco Designated VIP,
    2017 LAN
Reza
