WS-5483 and 4510 switches
Feb 19th, 2010
We inherited a 4510 switch with dual SupV and are trying to connect them to a 3845 router.  I purchased WS-5483 (copper GBICs) to accomplish this but they aren't working.  From everything I've read, these should work fine with these supervisors and the version of IOS that's running on them.  The problem is that they are not getting a link.  I know on the router, there is a command to specify media type.  Am I missing something in the configuration on either the switch or router that would cause these links not to work?  Basically have the uplink port on the switch set to a switchport but that's about the only configuration on the port.  Any ideas?
g.hammond Fri, 02/19/2010 - 14:01
Thanks for the quick reply.  The GBICs are going into a WS-X4516 running 12.2(25)EWA2, which according to the table in the link you provided should be supported.
Reza Sharifi Fri, 02/19/2010 - 14:38
  • Cisco Designated VIP,
    2017 LAN
Did you try a different patch cord.  Is there any way for you to test the ports with another box without using the GBIC to see if the issue is WS-5483?  You may have bad WS-5483
Reza
Leo Laohoo Fri, 02/19/2010 - 15:56
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
WS-5483, ahhhh ... I've received a number of WS-5483 that went back to Cisco because they were faulty.  What is the output to the command "sh interface status"?
Related Content
