Kureli Sankar Fri, 02/19/2010 - 14:17
You need to do the following through ASDM with that priv
15 user, then the Read-only and Monitor-only users will begin to work:
Currently, logging in with a user of privilegel 15, navigate to
Configuration > Device Administration > AAA Access > Authorization.
There is a button "Predefined User Account Privilege".  If you select
this and apply this, it wil set a series of commands to a lower
privilege based on what ASDM needs to authorize that user for either
Read Only or Monitor Only access.
Then you would need to create a new user account with privilege 5
access so that ASDM is read only, or create a new user with privilege
3 for monitor-only access.
-KS
smallrain_2 Fri, 02/19/2010 - 14:36
Thanks. I will try.
I assume this would allow users to navigate other pages (such as config)?
I just want others to see dash board, monitor (top attackers etc) only.
Anyway exported via RSS or similar?
