Unity 7.x Auto Attendant
Answered Question
Feb 19th, 2010
So far I am 90% on the way to creating a AA. Docs are only for older unity. here is what I have glenned out of many old documents.
Make an AutoAttendant
First Call Manager
1.       Create Non Secure Voice Mail Ports (5)
2.       Create Hunt List, Hunt Group, and Pilot Number, DONE!
Then Unity
1.       Create Port Group (Operator_Auto_Attendant)
2.       Create Ports(5)
3.       Created Call Handler Template Called (County Operator AutoAttendant)
4.       Created System Call Manager (County_Operator_Auto_Attendant) with extension 05956
5.       Call Routing à Direct Routing Rules: Added “Operator_Auto_Attendant” and Parameter “Edit Dialed Number”, Operator “IN” Operand Value 05956.
So is what am I missing?
Correct Answer by Rob Huffman about 7 years 5 months ago
Hey Neal,
You are most welcome (this is a nice description)
From Unity Master Lindborg;
https://supportforums.cisco.com/message/314244#314244
Cheers!
Rob
Hi Neal,
You're almost there
You didn't mention what is being played before your intended
recording. If it is "sorry" blah,blah,blah then is usually because the
recording was recorded as the "recorded name" rather than under
the actual Greetings section related to the Call Handler.
Cheers!
Rob
Overall Rating: 5 (2 ratings)
Neal haas Fri, 02/19/2010 - 16:57
Opps hit submit to fast.
when I call the number 05956 I get a anouncement before the message, if I press a 1 my calls get transferred as programmed. So how do I just get the AA message????
Correct Answer
Rob Huffman Fri, 02/19/2010 - 18:09
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Neal,
You're almost there
Cheers!
Rob
Neal haas Mon, 02/22/2010 - 08:22
It says "Sorry" then My Message Then "It is not available . . . ."
So how do I drop the greeting and ending.
Neal haas Mon, 02/22/2010 - 08:39
OK went to to System Call Handlers, Under Callers Hear Select "My Personal Recording"
Works great!!!!
Thanks for the pointers
Neal haas Mon, 02/22/2010 - 08:54
One last question, Do I need to record a message under the System Call Handler or can I upload a wav file?
Thanks Rob for your help!
