02-19-2010 05:26 PM - edited 07-03-2021 06:32 PM
I have broadcast ssid unchecked on my wlans, yet when we run airmagnet we see some aps seeing some of our wlans broadcasting their ssid?
02-19-2010 05:58 PM
Some wireless sniffers, such as AirMagnet, can pick up non-broadcasting SSID. Try the Windows Zero Config or use the Wi-Fi of your smartphones and verify.
02-20-2010 08:45 AM
It's a common security myth that not broadcasting an SSID provides some level of protection (if this was the reasoning behind turning off the broadcast). It's 100% untrue and can actually cause some (legitimate) clients to experience a delay before detecting the network they want is available to associate to.
Cheers,
Scott.
02-21-2010 07:30 PM
Hi Joe,
The reason why AirMagnet and other sniffers can see the SSID is because software like (AirMagnet) sniff the probe request frames coming from clients already preconfig with the SSID. if you capture the probe request from the client and open it up you will see the hidden SSID. AirMagnet will mark the SSID with the color RED on the dashboard. This is an indication the ssid was not being broadcasted.
Other sniffers like NetStumbler only looks for broadcast frames.... this why you will not see the "hidden" networks.
Make sense?!
If you find this post helpful please rate the post!
