02-19-2010 08:46 PM - edited 03-11-2019 10:12 AM
Most of the time everything works fine on the firewall and all the required traffic is passing through the firewall as expected by the configuration.
Sometimes some of the users are not able to a)go online, b)access the servers.
the users facing this issue are able to work with the existing connections but if they try to open a new connection to any servers they fail.
At that time users are not able to go online either. I am able to ping that time but i am not able to telnet.
servers are in one security level and users are in different security level.
If they user remove the lan cable and refix it everthing works normal for that user.
Arulkumar
Solved! Go to Solution.
02-20-2010 12:47 PM
Don't have any logs from the time when the problem happened?
Are you reaching the limit of connections permitted?
Federico.
02-21-2010 06:57 AM
The ''show conn count'' will show you amount of connections at a certain point, you can compare this number to the max. connections that your specific model can handle.
Also, for the servers, they have a limit on the amount of embryonic connections and total connections as well on the STATIC command. (The same applies for dynamic NAT).
If the problem is with the amount of traffic, a temporary solution is to change the timeouts for the XLATEs and connections: ''sh run timeout''
Federico.
02-20-2010 12:47 PM
Federico.
02-21-2010 12:49 AM
Federico.
Hi Federico,
Thanks for your reply.
How can i check if ASA is reaching the limit of connections permitted. (any command to check that)
Arulkumar
02-21-2010 06:57 AM
Federico.
02-21-2010 10:11 PM
The information was useful
Will check that......
Arulkumar
02-22-2010 06:03 AM
from sh conn i see that device can handle more number of connection.
will reducing the timeout for xlate and connection work?
because the only some of the hosts are not able to connect to a servers or go online and it is happening sometimes only sometimes
after few minutes the hosts are able to connect to severs and go online normally.
when the issue is occuring ping works fine
and if the host"s lan cable is unlugged and relugged back the issue is resolved, they are able to connect to servers an able to go online.
Servers are connected in 1 interface and internet is on another interface
hope my explanation is clear.
Your help is much appreciated.
Arulkumar
02-22-2010 01:30 PM
Will be a good test to try lowering the timeouts for the translation and connections...
Just make sure, the XLATE timeout should be greater than the CONN timeout.
Let's see the results...
Federico.
02-25-2010 09:28 PM
tried lowering the timeouts for the translation and connections, no good....
please advise.
Arulkumar
02-26-2010 05:58 AM
Arulkumar,
We just can't manipulate the timeout not knowing what the cause it.
What do the logs say when these hosts can't go out?
Can they ping the firewall's IP address?
Can they get name resolution when they ping yahoo.com or google.com
Can they load the page by IP address and not name?
Can they ping an outside IP through the firewall?
Only TCP breaks? ICMP works?
enable logging on the firewall
conf t
logging buffered 7
sh logg | i x.x.x.x
where x.x.x.x is the host that cannot got out. Explain what protocol (http ?) breaks. You are trying a telent x.x.x.x 80 to verify?
-KS
