02-20-2010 07:40 AM - edited 03-04-2019 07:34 AM
I have 1 ADSL Router where 2 ADSL lines are getting terminated. This ADSL Router is connected to a 2960 L2 switch where ASA Outside Inetrfgace is also getting connected. ASA Inside Interface is connected with 6500 L3 Switch where all users are located.
I want to do Load Balancing between these 2 ADSL Lines with Failover.
Note: I don't want Load Balancing based upon VLAN.
02-20-2010 07:51 AM
02-20-2010 08:10 AM
02-20-2010 01:23 PM
Just set default routes to same weight.
02-22-2010 01:18 AM
loadbalancing or failover not support on ADSL connection.
02-22-2010 01:30 AM
Incorrect, refer to the link I have posted above.
02-22-2010 02:03 AM
