2611xm Terminal Server + ACS + duplicate login when using menu options
Feb 20th, 2010
I'm trying to set up ACS on my 2611xm router, so far I have been able to do this, however when you login,
I have a autocommand setup to run a menu. My problem is when you select the option on the menu it
reauthenicated against the router again before connecting to the line, can any one tell me how to stop this from happening.
Thanks for your time and effort in advance, I have enclosed a config below.
DDRAS01#sh running-config
Building configuration...
Current configuration : 6854 bytes
! Last configuration change at 10:28:49 AEST Sun Feb 21 2010 by <removed>
! NVRAM config last updated at 19:25:53 AEST Sat Feb 20 2010 by <removed>
version 12.4
service password-encryption
service linenumber
service sequence-numbers
hostname DDRAS01
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 informational
logging rate-limit all 10000
logging console critical
enable password 7 <removed>
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login if_needed local
aaa authentication enable default enable
aaa authentication ppp default local
aaa authorization exec default group tacacs+ local if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
clock timezone AEST 10
clock summer-time AEST recurring last Sun Oct 2:00 last Sun Mar 3:00
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip domain list <removed>
ip domain name <removed>
ip host dd-cr-01e 2033 172.16.1.1
ip host ddsws01 2034 172.16.1.1
ip host ddsws04 2035 172.16.1.1
ip host ddce565 2040 172.16.1.1
ip name-server <removed>
username netops privilege 15 password 7 <removed>
ip ssh source-interface FastEthernet0/0
ip ssh logging events
ip ssh version 2
interface Loopback0
ip address 172.16.1.1 255.255.255.255
ip address <removed> 255.255.255.0
speed 100
full-duplex
interface Serial0/0
no ip address
shutdown
interface BRI0/0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 <removed>
ip http server
no ip http secure-server
ip tacacs source-interface FastEthernet0/0
ip radius source-interface FastEthernet0/0
logging facility local6
logging <removed>
snmp-server community <removed> RO
snmp-server community <removed> RW
snmp-server location <removed>
snmp-server contact NetOps
menu ddras01 title ^C
Cisco Terminal Server
Select the number from the list below
Use 'ctrl+shift+6' then 'x' to switch back to the menu
^C
menu ddras01 text 1 Connect to DD-CR-01
menu ddras01 command 1 resume dd-cr-01 /connect telnet dd-cr-01 2033
menu ddras01 text 2 Connect to DDSWS01
menu ddras01 command 2 resume ddsws01 /connect telnet ddsws01 2034
menu ddras01 text 3 Connect to DDSWS04
menu ddras01 command 3 resume ddsws04 /connect telnet ddsws04 2035
menu ddras01 text 8 Connect to DDCE565
menu ddras01 command 8 resume ddce565 /connect telnet ddce565 2040
menu ddras01 text 9 Exit
menu ddras01 command 9 menu-exit
menu ddras01 clear-screen
menu ddras01 status-line
menu ddras01 line-mode
tacacs-server host 10.2.0.50
tacacs-server directed-request
tacacs-server key 7 <removed>
control-plane
privilege exec level 15 write terminal
privilege exec level 1 ping
privilege exec level 10 undebug ip icmp
privilege exec level 10 undebug all
privilege exec level 10 terminal monitor
privilege exec level 15 show running-config
privilege exec level 5 show configuration
privilege exec level 10 debug ip icmp
privilege exec level 10 debug all
privilege exec level 10 clear interface
privilege exec level 10 clear counters
line con 0
logging synchronous
line 33 64
no exec-banner
exec-timeout 0 0
no activation-character
no exec
transport preferred telnet
transport input all
escape-character 27
stopbits 1
flowcontrol hardware
line aux 0
line vty 0 4
logging synchronous
autocommand  menu ddras01
line vty 5 181
logging synchronous
ntp clock-period 17208487
ntp source FastEthernet0/0
ntp server <removed>
end
