packet tracer and 2950
Answered Question
Feb 20th, 2010
after enabling router  ports and before any config why I get connectivity on link R---SW2960 and no connectivity on link R --- SW2950
and the port is enabled on SW 2950
but I get this line on show command
Switch#show int fa 0/1
FastEthernet0/1 is down, line protocol is down (disabled)
Correct Answer by Kevin Dorrell about 6 years 11 months ago
... or it could be that you are using crossed cables.  Between a router and a switch, you should use a straight cable.  The 2960 has auto-crossover detection, but the 2950 does not, so the 2960 can compensate for having the wrong type of cable.
Kevin Dorrell
Luxembourg
Overall Rating: 5 (1 ratings)
glen.grant Sun, 02/21/2010 - 03:45
   One end or the other is not turned up   or a  bug in the program.  If it lets you post configs maybe you can post here.
Correct Answer
Kevin Dorrell Sun, 02/21/2010 - 10:07
Kevin Dorrell
Luxembourg
