Adding new vlan to exixiting FWSm
Answered Question
Feb 21st, 2010
Hi All,
We need to add  a new vlan and allow this to FWSM I have checked that there is no option for add in the firewall vlan-group command. I want to know if typed the command with existing vlan and the new vlan does it cause any isussues to the running environment.
Correct Answer by Jon Marshall about 7 years 2 months ago
khader1977 wrote:
Hi All,
No it won't cause any issues to the running environment but obviously if the vlan you add had any devices on it then they could be affected. You don't need to type out the full list again either. So if you had
firewall vlan-group 1 10,12,15
and you want to add vlan 30 then just type
firewall vlan-group 1 30
this will simply add vlan 30 to the existing list ie. it won't overwrite what is already there.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Sun, 02/21/2010 - 06:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
khader1977 wrote:
Hi All,
Jon
khader1977 Sun, 02/21/2010 - 07:09
Hi Jon,
Thanks for the reply it worked
thanku very much
