Numbering Plan
Feb 21st, 2010
Hi all,
Currently, i configure cucm 7.1. I have added route pattern 9.! point to E1 line. I wonder why call to certain celular provider is dropped, on the other hand call to international, local, long distance number, a few celular provider is working. I haven't configure any partition and CSS.
Is there anything i have to do with the numbering plan in route pattern 9.!? I installed the cucm in Indonesia.
Overall Rating: 4 (1 ratings)
stowellp Sun, 02/21/2010 - 05:35
I would do a debug on the gateway - debug isdn q931 to check that what digits you are sending to the service provider. If you are sending all of the correct digits then you will need to call your provider.
I've had a situation before when the provider was only accepting 11 digits from the gateway and disgarding the rest. The mobile number had 12 digits so the number was not being connected to the mobile.
triandi_sugiharto Sat, 02/27/2010 - 05:59
Hi stowellp,
You're right, it seems that the provider has not opened the call to certain number.
Related Content
