02-21-2010 07:37 AM - edited 03-11-2019 10:12 AM
I am able to login to FWSM ASDM, but the GUI page after login is not coming.
It get stop after Software Update Completed.Please find the attachment.
What will be the cause? Please help.
Anil
Solved! Go to Solution.
02-21-2010 11:27 PM
can you check that FWSM cpu usage.because we too have the same kind of problem because of high cpu utilization.
other than that check the ASDM image status in both primary and secondary FWSM module.
regards
karuppu
02-21-2010 02:01 PM
Anil,
Make sure you are running the latest java on the client. Pls. go to http://www.java.com/en/download/manual.jsp and get the latest java.
Also check
sh run http
and make sure the client IP has permission to access via asdm
Make sure you are running the correct asdm version for the OS on the FWSM.
You can check here:
You can get the following version.
asdm-615f.bin | |
Release Date: 14/Jul/2009 | |
Cisco Adaptive Security Device Manager for FWSM 3.1, 3.2 and 4.0. | |
Size: 11221.19 KB (11490496 bytes) |
-KS
02-21-2010 10:42 PM
02-21-2010 11:27 PM
regards
karuppu
02-22-2010 12:03 AM
I have uploaded the new ASDM image and its working; don't know why?
Why it was not working working with old ASDM image?
Any clue?
Anil
02-22-2010 05:57 AM
Anil,
Depending on what windows update your client recd. we have seen issues like this and that is the reason I suggested to upload the latest ASDM and java on the client.
-KS
02-22-2010 06:04 AM
We have uploaded new ASDM image on Cisco FWSM.
We have not done any thing on the client machine.
Anil
