GRE/IPSec Tunnel using Loopback Interface as Source
Patrick Murphy
Hi All:
I need a to switch a currently working router to router VPN tunnel from using a WAN interface IP address to a loopback inteface IP as the source.  I am able to ping the loopback from the other router.  As soon as I change the tunnel source to use the loopback IP, change the crypto map ACL, and move the crypto map from the WAN interface to the loopback interface, the tunnel will not come up.  If I remove all the crypto config, the tunnel comes up fine as just an GRE tunnel.  On the other router, I see the below message which looks like it isn't encryption the traffic.
*Mar  1 00:10:33.515: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.0.1, src_addr= 192.168.1.2, prot= 47
What am I missing?  Is there anything else that needs to be done to use the loopback for a GRE/IPSec tunnel?
I've setup the below config in the lab to see if I can even get it working in a non-production enviroment.
R1 WAN IP: 192.168.0.1
R2 WAN IP: 192.168.0.2
R2 Loopback: 192.168.1.2
hostname R2
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key abc123 address 192.168.0.1
crypto ipsec transform-set T1 esp-3des esp-md5-hmac
mode transport
crypto map VPN 1 ipsec-isakmp
description Remote
set peer 192.168.0.1
set transform-set T1
match address VPN1
interface Loopback0
ip address 192.168.1.2 255.255.255.255
crypto map VPN
interface Tunnel1
ip address 172.30.240.2 255.255.255.252
ip mtu 1440
keepalive 10 3
tunnel source 192.168.1.2
tunnel destination 192.168.0.1
crypto map VPN
interface FastEthernet0
ip address 192.168.0.2 255.255.255.0
ip access-list extended VPN1
permit GRE host 192.168.1.2 host 192.168.0.1
francisco_1
Level 7
Level 7
have you tried adding "crypto map VPN 1 local-address Loopback0"
5 Replies 5
francisco_1
Level 7
Level 7
Example
crypto dynamic-map dyna1 10
set transform-set 3des-sha
reverse-route
crypto map vpn1 local-address Loopback0
crypto map vpn1 100 ipsec-isakmp dynamic dyna1
interface (Interface you/re terminating crypto)
description INTERNET_FACING_INTERFACE
ip address
crypto map vpn1
Actually, this fixed it.   It was a combination of adding "crypto map VPN local-address Loopback0" and keeping the "crypto map VPN" on the WAN intefaces (not on the loopback).
Thanks for everybody's help!
Patrick
Patrick Murphy
I tried your suggestion of adding "crypto map VPN local-address Loopback0".  However, it doesn't look like that fixed it.
For the dyamic-map, I'm not sure I understand what that is trying to do.
Thanks for the help.
Leo Laohoo
I'm seeing some inconsistency here.
and
Should this be "crypto isakmp key abc123 address 192.168.1.2"?
