Communications Manager 6.1(5) upgrade hangs
Feb 21st, 2010
We are required to validate all upgrades in the lab prior to doing
them in production.  This has revealed a somewhat unusual problem.
I have built a VMWare image and upgraded it to 6.1(4a)SU2 several times.  When I attempt to upgrade to 6.1(5) using the image of CCO (yes, it properly checksums), it consistantly hangs in the same spot.
Consistantly it's occurring and within a few lines of the same place.  The logs on the last attempt show it hanging at this point:
02/21/2010 13:38:01|Copying "././RedHat/APPRPMS/cm-ccmhelp-" to "/common/rpm-archive/"|<LVL::Info>
02/21/2010 13:38:04|Copying "././RedHat/APPRPMS/cm-ccmivr-" to "/common/rpm-archive/"|<LVL::Info>
02/21/2010 13:38:04|Copying "././RedHat/APPRPMS/cm-ccmmib-" to "/common/rpm-archive/"|<LVL::Info>
Has anyone else seen this, or is anyone aware of a cause/workaround for this?
gogasca Sun, 02/21/2010 - 13:15
Are you using SFTP or DVD ?
Is failing PUB or SUB?
Can you please get Install logs?
Clifford McGlamry Sun, 02/21/2010 - 13:17
I was using DVD.  I finally got it to finish.  Had to kill the running process that was hung (which hasn't always worked in the past).  Then rebooted it a
nd started it again, and it successfully completed.
6 attempts to get it to work leaves me nervous about this one.
Related Content
