SSH to ACS SE
Feb 21st, 2010
I could not SSH to ACS SE appliance? Any idea why I could not, however I can do on another ACS SE.
Please note that I can ping the ACS SE, after disabling the CSA, so netowrk connectivity is ok.
Cisco Secure ACS: 4.2.0.124.
Thanks and Regards,
Ganesh Hariharan Sun, 02/21/2010 - 23:41
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Thanks and Regards,
Can you check in ACS GUI under reports & activity under Appliance status page and check TCP port 22 is opened or not in ACS SE,If yes then check between your system and ACS SE any firewall is there if yes then also open port 22 in firewall also.
Ganesh.H
Ahmed Shahzad Mon, 02/22/2010 - 14:34
Hi Ganesh,
Thank you for your response.
TCP port 22 is open, and there is no firewall between system and ACE SE.
Thanks and Regards,
Shahzad.
Ganesh Hariharan Tue, 02/23/2010 - 04:11
Hi Ganesh,
Thanks and Regards,
Shahzad.
Hi Shahzad,
If there is no firewall between the ACS and client and port 22 is open then i would suggest you to try restart the ACS services and then check are you able to get ssh prompt.
Hope to Help
Ganesh.H
Ahmed Shahzad Tue, 02/23/2010 - 14:40
Hi Ganesh,
Thank you for your response. I will already tried to restart the ACS, but it does not worked. I have tried to access the ACS from a system on the same subnet as of ACS, but it also did not worked.
Thanks and Regards,
Ahmed Shahzad.
Related Content
