Recommended device for ADSL edge of an SA500?
Feb 21st, 2010
OK, so I want unified threat management and the 4 x 1Gi ports of the SA500, but I connect to the WAN using ADSL.  What ADSL modem do Cisco recommend in this case, seeing as there isn't one in the SB Pro product range?
thanks,
David.
Glenn Quesenberry Mon, 02/22/2010 - 13:21
  • Cisco Employee,
David,  The only xDSL devices we have are the SR500 series routers which sounds like overkill for your scenario.  With that said we can't make any specific recommendations on any specific xDSL modems but any that your xDSL provider specifies, recommends or provides should not be a problem as long as it provides a standard Ethernet hand-off to the SA500.
Best Regards,
Glenn
