Traffic flow
Feb 21st, 2010
I am  trying to know how routing works. Please bear with me
For eg --I have L2 switch attched to the core1.
L2 switch has default gateway of 192.168.253.1 (this sits on core 1 as an SVI)
Core 3 has L2 Swi hanging off with vlan 230 SVI.
Core 1 & Core 2 do not have vlan 230 on it
L2 Swi1 has vlan 253 and vlan 230
All core switches are 6513 switches
Core 1 has access connection of vlan 253 to core 2 and core 2 has access connection of vlan253 to core 3 .All core switches have Ospf running . I cannot change the these access connections in the core so please advice me according to the configuration below
L2 Swi1<-------vlan253 ------>Core 1 <---------->vlan 253<---------->Core 2<---------vlan 253--------> Core3------------L2 Swi2 (vlan 230)
Q1 when L2 Swi1 sends traffic for vlan 230 to Default gateway Core 1 how can it reach L2 Swi2 off of core 3 ie . where do i need put SVI in order for packet   to reach destination of vlan 230  at Swi2. I don't want to create trunks in the core.
Q2 Is this possible thru routing or the only way to go is thru trunks or access connections.  Do i need vlan 230 on  Core 1  & Core 2  in order for this to work?
Q3 If possible thru routing can anybody please explain the  configuration i need to put on the core or switches?
Please Advice
I wll appreciate it.
Reza Sharifi Sun, 02/21/2010 - 19:44
  • Cisco Designated VIP,
    2017 LAN
Please Advice
Q1 for vlan 253 you should put the SVI in core-1 switch. Also for vlan 230 you should put the SVI on core-3 If you have any vlan hanging off of core-2 then put the SVI for that vlan in core-2.   You will also need to deploy /30 subnets between all you core devices
Depending on the type switch you have you can then run a routing protocol like OSPF, RIP or ISIS between core-1, core-2 and core-3.
Reza
gurkamal01 Sun, 02/21/2010 - 19:48
Jon any advice on this?
The core switches are 6513
Thanks in advance
Reza Sharifi Sun, 02/21/2010 - 19:57
    2017 LAN
Between your 6513 switches you can enable OSPF (as long as you have the right image) or you can also use static routes since this is small network
Reza
gurkamal01 Mon, 02/22/2010 - 10:29
Jon can you advice on this please
Thanks in advance
