02-21-2010 11:19 PM - edited 03-19-2019 12:30 AM
Hi All,
I Installed Unity Connection 7.0.2 and it works fine. My problem with Cisco PCA access.
I am not able to access the PCA. I am using this link:
https://ServerIP:8443/ciscopca/home.do
I am using my username and password, I used my password for TUI and AD ( the Unity integrated with AD).
My username added to the COS with the following:
If I tried to access the following message appear:
Log on failed - Invalid User ID or Password
02-22-2010 06:01 AM
Hey JFV,
Maybe you are seeing the issue detailed in this thread with
nice answers from Neha,Tommer and John
https://supportforums.cisco.com/message/1211610#1211610
Cheers!
Rob
02-22-2010 01:20 PM
Thank you too much Rob,
But I am not able to find the answer for my case.
What I understod from the post is:
for using LDAP authentication for ciscopca, we will have to import users
from LDAP integration.
For me I do not care ( I just need to login, whether I used CUCM passwords , AD or Local I jsut need to login in any method )
but the actual scenrio is both CUCM nad CUC are integrated with LDAP and I IMPORT USERS FROM LDAP. I belive that I have problem with authintication throw LDAP ( I am not sure)
Is there any way to login using Local Passwords I do not need LDAP.
and what I should tupe to login shall I add the domain to username or no? In unity there is a feiled to enter the domain, what about Connection??
02-25-2010 02:43 AM
I tried to add user on the same server with out importing from AD. and the same problem
any body can tell me what is the username and password that I should use ?
02-25-2010 05:41 AM
Hey JFV,
Sorry that I missed your reply earlier
The username should be the alias as set up in Unity Connection and
the password is what is set as the Web administration password for the user.
Hope this helps!
Rob
