Unity Express problem !!
anis_cisco
hi all,
I have CCME with CUE installed .. once im entering into CUE via service-engine comand im getting these errors again & again continuously after some time
" Cisco-UnityExpress# ERROR sysdb misc allocation (Success) fixtab_ref from nonposi
tive refcount (-7617 @0x402c2b08)
ERROR sysdb misc allocation (Success) fixtab_ref from nonpositive refcount (-761
6 @0x402c2b08)
ERROR sysdb misc allocation (Success) fixtab_deref negative refcount (-7616 @0x4
02c2b08)
6 @0x402c2b08)
ERROR sysdb misc allocation (Success) fixtab_deref negative refcount (-7615 @0x4
02c2b08
can any one tell what these errors means ????
5 Replies 5
paolo bevilacqua
Whatever they means, you should try to backup config and reinstall CUE again.
hi,
Thanks for your reply. Its new installtion of CUE, as i access Unity Express First Time i started to get these msgs & wat do you mean by reinstall ?? do you mean i need to do configuration or i need to reinstall unity module ????
Likely something has not worked and you have to install the software again from scratch.
hmmmmm... its a brand
new box from cisco .... how this could be possible that some thing is not working !!!! should i update the unity software ??
As indicated before twice: reinstall software.
