CUCM 5.1 upgrade to 7.1 on MCS-7825i4-k9
Feb 22nd, 2010
I have a CUCM 5.1(x) running on production servers (older MCS). I want to migrate it to version 7.1(x) on a new server platform MCS-7825-i4-k9. Upgrade on existing MCS (older one) to version 7.1(x) is not supported Installation  neither is 5.1(x) on this new MCS-7825-i4-k9 platform. Any one had this problem before ??
thanks.
Overall Rating: 4 (1 ratings)
Rob Huffman Mon, 02/22/2010 - 06:55
Hi Marius,
You will be one of many,many people who will run into
this issue because of the compatibility issues between the
"old" and "new" MCS versions. I don't know why Cisco has
to make this so complicated for people The only method
that is going to work here (that I can think of) is to find a "mid-point"
release that is able to be built on both MCS models. Upgrade the old
boxes to this version - build the same "mid-point" version on the new
boxes and use DRS to move the dB. This is the only way that seems
to be viable (what a pain!)
Here are the references to work with;
Supported Server Models:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Supported CUCM Upgrades:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
Cheers! I hope someone has a better method.
Rob
mariusgggg Mon, 02/22/2010 - 22:55
Hi Rob,
You came up with a best solution , we might try vmware also.
thanks very much for help.
